Xgen-lists
Eleni Tousidou etousido at athena.auth.gr
Tue May 14 08:00:00 EDT 1996
I am working at Xgen program and I am using lists with a 'multiple'
listtype. The problem that I have is that when I select more than one
elements from the list, only the first one is returned as a value of the list
and the rest are ignored. The listseparator is either a " "  or a ",".  It
doesn't seem to be 'valuestring's ' fault. Can anybody help?
Thank you.
