ps.map - linux
anthony burns KY#c#KY.BLNKY01#c#agburns at KCC.FSA.USDA.GOV
Tue Jan 27 07:00:00 EST 1998
Linux grass users
I ps.select the printer driver ie hp650D, a3 or whatever, it accepts it just
fine. I then use ps.map to develop the map.  After I respond to all questions
and give a file name to output the map, the process begins , I see ps.map selec
t
the printer and then it immediately core dumps with a segmentation fault.
Any ideas as to what the problem is.
Thanks
Anthony
