[GRASS5] 64-bit PVF patch (read-only)
Bill Hughes bhughes at grasshoppernet.com
Tue Dec 28 19:47:07 EST 1999
If anyone was holding his breath waiting for this patch, you
can exhale now.  I have a tarball on my webpage at
http://www.grasshoppernet.com/~bhughes that contains enough
code to allow Alpha-platform machines to read the Portable
Vector Format.  I do not recommend it as a general-use patch.
It "ought to work" on non-Alpha machines, but that's easy to
say and harder to prove.  Apply to 5.0beta6d source.
Using this patch will disable access to the native-sized
pseudo-version-4 vector files that Alphans have been using, so
if you _need_ this you should continue using the PORT_LONG=8
hack.  (and why are you using an Alpha in production???)
I have successfully drawn several of the vector maps in the
Spearfish examples, just to see what the rest of you have been
working on.  I expect that there are still bugs.  There is PVF
writing code in this patch, but it has not been tested.
This patch is an interim fix for a 64-bit architecture
until somebody does the job properly.  This re-write has given
me valuable insight, and this code is not part of The Plan.
Bug reports are welcome, or something-
Bill Hughes
If you want to unsubscribe from GRASS Development
Team internal mailing list write to:
minordomo at geog.uni-hannover.de with
subject 'unsubscribe grass5'
length: 1875
max: 0
