[GRASS5] Re: r.cost
Carl Anderson candrsn at fultonecd.org
Mon Apr 24 16:32:03 EDT 2000
Markus Neteler wrote:
> INFINITY is defined in
> /usr/include/math.h:    INFINITY        representation of the infinity value of type
'float'
> If r.cost is not compiling on your machine, I assume your compiler
> is not installed properly. The declarations in src/raster/r.cost seems
> to be o.k.
My Redhat 6.1 boxes have INFINITY defined in <bits/mathdef.h>  through
#includes from <math.h>
My Solaris 2.5.1's and 2.7's do not have such a definition
  even in usr/local/lib/gcc-lib/sparc-sun-solaris2.7/2.95.2/include
        I stuck a define into globals.h
        as a suffuciently large number
        to get the module to compile
NAN, INFINITY and some others are not consistent Linux to Linux, Unix to
Unix, Compiler to Compiler.
C.
Carl Anderson
Fulton County, Georgia
Environment & Community Development
GIS
404 730-8026
If you want to unsubscribe from GRASS Development
Team internal mailing list write to:
minordomo at geog.uni-hannover.de with
subject 'unsubscribe grass5'
length: 2175
max: 0
