[GRASS5] New makefiles - work in progress, take 'em for a spin
Eric Mitchell emitchell at altaira.com
Thu Aug 3 10:35:35 EDT 2000
Attached is a .tgz of the new makefile work I've been
up to.  If you're adventurous, try it out as follows:
1) from within the top level grass distribution directory
	gunzip -cd grass.remake.tgz | tar xvf -
2) if you're using Linux, you'll probably be ok.  If not,
    you'll have to copy the contents of src/CMD/head/head
    into the include/Make/Platform.make file.  There are
    a handful of macro definitions at the end of the file
    that will need to be edited for your platform of choice.
3) type "make"
4) get coffee, tea, or non-caffeinated beverage and
    enjoy the show.
5) type "make install" and watch a bunch of files get
    copied to locations under $GISBASE/$ARCH.  Note that
    files that can be shared by multiple platforms can
    be in the same installation tree, as the platform
    specific files are installed under unique subdirs.
6) let me know if I'm on the right track here, and should
    bother with completing the makefiles, editing startup
    scripts to use the shared libs, etc.
-- ebm
| Eric B. Mitchell         mailto:emitchell at altaira.com |
| tel: (301) 809 - 3534    Altair Aerospace Corporation |
| tel: (800) 7 - ALTAIR    4201 Northview Dr. Suite 410 |
| fax: (301) 805 - 8122    Bowie, MD  20716             |
              ,___
          /"\  / o=\  /"""---===/
         /   \_/  \__/   ---===/
         |    //\   || /""TT""/ //\   || ||""\
         |   //  \  ||    ||   //  \  || ||__/
         |  //--==\ |L--/ ||  //--==\ || || "=,
           \____---===/
Type: application/octet-stream
Desc: not available
Url : http://lists.osgeo.org/pipermail/grass-dev/attachments/20000803/7958ea48/grass.remake.obj
