[GRASS5] new vector
mi.ro at iol.it mi.ro at iol.it
Thu Dec 28 12:49:01 EST 2000
> Hi all,
> i would like to discuss some problems related to new vector
> format/library i am working on.
> 1) Little or big? Dig files are written (version 4) in portable vector
> format which is big endian byte order (note for David: I was wrong
> in my last mail).
> On little endian machines (i386 for example) byte order of each
> number must be changed. My test with d.vect says that such
> conversion takes 8% of time
Hi Radim.
I've used, in the past, a little different model, where you
check if the file byte-order matches or not the current platform
byte-order. Thus avoiding unrequested conversions.
In this case one should have the possibility to write files in both
big and little endian flagged by a specific field, and/or
be able to convert them.
Ciao.
If you want to unsubscribe from GRASS Development Team mailing list write to:
minordomo at geog.uni-hannover.de with
subject 'unsubscribe grass5'
