[GRASS5] projection-transformation
Michel Wurtz mw at teledetection.fr
Fri Dec 22 13:34:27 EST 2000
Markus Neteler wrote:
> May there be a bug in m.in.e00 which I used for data import?
Well... m.in.e00 doesn't translate anything. It uses the
scale factor in projection info if it is not 1.0.  A bug
here may lead to a false scale (and a non uniform shift)
Did you look at the original e00 file ? (take in dig_att the
attribute of the vector, and use it to search through
the arc section of the e00 file : you should find the same
lat/long values than in the grass vector file).
Michel WURTZ - DIG - Maison de la télédétection
               500, rue J.F. Breton
               34093 MONTPELLIER Cedex 5
If you want to unsubscribe from GRASS Development Team mailing list write to:
minordomo at geog.uni-hannover.de with
subject 'unsubscribe grass5'
