[GRASS5] [GRASS-bugs] Bugreport GRASS 5
Markus Neteler neteler at geog.uni-hannover.de
Mon Dec 18 08:47:50 EST 2000
On Mon, Dec 18, 2000 at 09:37:00AM +0000, Wwises at hpcc.nectec.or.th wrote:
> Below is the result of your feedback form.  It was submitted by
>  (Wwises at hpcc.nectec.or.th) on Monday, December 18, 2000 at 09:36:58
> subject: Bugreport GRASS 5
> platform: Linux/Intel
> vendor: RedHat
> cputype: Intel (i486, i586, pentium ...)
> grassversion: Linux/Intel binaries
> cvsyesno: -- select --
> source_version: 5beta10
> module: X window repaint
> bugreport: I have the repaint problem listed in the FAQ that X won't repaint the monitor when I drag a window over the monitor. I did the steps in the FAQ and my XF86Config file has the following:
> # Graphics device section
> # Any number of graphics device sections may be present
> Section "Device"
>     Identifier        "Generic VGA"
>     VendorName        "Unknown"
>     BoardName "Unknown"
>     Chipset   "generic"
>     Option "backingstore" "on"
> #    VideoRam 256
> #    Clocks   25.2 28.3
> EndSection
> # Device configured by Xconfigurator:
> Section "Device"
>     Identifier  "nVidia Corporation|Vanta [NV6]"
>     BoardName   "Unknown"
>     #VideoRam    16384
>     # Insert Clocks lines here if appropriate
> EndSection
> As you can see, the backingstore feature has been set but the problem
> still persists. Any clues as to what to do?
which Xfree are you using? Which windows Manager?
Myself, the problem also persists on Xfree 4.0.1 and KDE 1/2.
Xfree 4.0.1 with fvwm2 is fine.
Time to investigate!
 Markus
If you want to unsubscribe from GRASS Development Team mailing list write to:
minordomo at geog.uni-hannover.de with
subject 'unsubscribe grass5'
