[GRASS5] nviz
Helena Mitasova - staff
helena at gis.uiuc.edu
Sun Dec 17 13:59:30 EST 2000
>nviz2.2 -q el=hoehen_test
I am not sure whether that is a problem, but -q does not
expect anything after it - it is supposed to open
nviz without any data (and you can then load everything
from e.g. your state file saved from your previous work.
-q did not work in pre-beta10 versions, it was supposed
to be fixed, but maybe the fix is not 100% done.
so it should be either nviz2.2 -q
or nviz2.2 hoehen_test
>module: r.out.ascii
>bugreport: dp paramater doesn't seem to work. All output ascii files
>are integer regardless whether the source map is integer,
>float, or double.
I have used r.out.ascii with dp without problems in beta8 - has
anything changed that cold have messed it up in beta10?
(I haven't dowloaded beta10 yet, I hope to get to it next week.)
Helena
If you want to unsubscribe from GRASS Development Team mailing list write to:
minordomo at geog.uni-hannover.de with
subject 'unsubscribe grass5'
