[GRASS5] Some Bugs
Markus Neteler neteler at geog.uni-hannover.de
Wed Dec 13 04:16:06 EST 2000
Eric and Frank Warmerdam,
On Wed, Dec 13, 2000 at 12:09:05AM -0800, Eric G . Miller wrote:
> On Mon, Dec 11, 2000 at 12:17:34AM -0800, Eric G . Miller wrote:
> > Okay, So I got around to installing libgeotiff and libgdal, so I could
> > try r.in.gdal.  Well, it incorrectly identifies the projection.  I think
> > the problem may be related to some of the projection info functions
> > since I subsequently discovered all of the files I had been working with
> > in a particular dataset have:
> Okay, I'll refile this as a bug against r.in.gdal, since after some
> futzing around, I couldn't reproduce whatever led up to my losing the
> "zone" information. r.in.gdal seems to think this projection is 'll'
> with WGS84 ellipsoid, but g.region -p gives:
> projection: 1 (UTM)
> zone:       10
> datum:      nad83
> ellipsoid:  GRS80
> north:      4287336.36938346
> south:      4286992.24959761
> west:       702638.44204432
> east:       703010.87980807
> nsres:      0.39782634
> ewres:      0.38876593
> rows:       865
> cols:       958
Frank, may I ask you to give us a hint?
> While I'm thinking about it; why do we have ellipsoids GRS80/grs80 etc.?
> Aren't they the same?  And if so, why does specifying ellipsoid=grs80
> and then specifying datum=nad83 generate an error?  If there's some
> reason for having both upper and lowercase names for these,
> can't we just "alias" the names somehow?
Eric,
actually I can't find grs80 in the lists...
However, I agree to support lowercase names only. Additionally the routine
reading in the ellipsoid/ etc. should always change the input
letters of the user to lowercase.
If there are no objections, I will change
src/libes/gis/ellipse.table
to lowercase names.
> And to be even more of a pest.  Is there something special about UTM?
> why should it be handled differently than all the other projections?
> Seems we should have:
> XY data (unreferenced)
> Unprojected (lat/lon)
> Projected (projection)
> I know there's a hysterical (I mean historical) reason for this, but it
> would seem logical to do this.
Again I agree. Should be more clear here. Maybe UTM and States Plane
was an extra entry as GRASS has been an U.S. only development. But
nowadays in worldwide use you proposal is more intuitive.
Related question to UTM: Why is the Zone letter not required (sorry, I am
no UTM expert). For Germany it is 32U, but GRASS only wants to know 32.
This I don't understand...
Markus
If you want to unsubscribe from GRASS Development Team mailing list write to:
minordomo at geog.uni-hannover.de with
subject 'unsubscribe grass5'
