[GRASS5] Misc. Module Errors
Jeshua Lacock jeshua at SierraMaps.com
Sun Dec 10 19:14:38 EST 2000
On Tuesday, December 5, 2000, at 11:20 PM, Eric G . Miller wrote:
> > v.in.shape reported an error that it could not access malloc.h, so
> > after copying malloc.h from
> > "/System/Library/Frameworks/System.framework/Versions/B/Headers/bsd/sys/"
> > to "src/include/" it only gets one error:
> malloc.h should be part of the Standard C lib.  I'm thinking there must
> be a problem somewhere between the C preprocessor, and the compilation
> phase.  Based on your other error reports, it would seem various macros
> in included header files may not be getting expanded correctly, and
> hence generating errors.  All the 'illegal expression, found }' lead me
> to believe that some kind of expansion is happening in the preprocessor
> that is generating illegal code for the compiler.  Also, could be this
> thing with the switch construct (see below).
> > /usr/src/grass/src/mapdev/v.in.shape make -f
> > OBJ.powerpc-apple-darwin1.2/make.rules cc -g -O2
> > -I/usr/src/grass/src/include  -c shp2dig.c -o
> > OBJ.powerpc-apple-darwin1.2/shp2dig.o shp2dig.c:807: illegal
> > expression, found `}' make: ***
> > [OBJ.powerpc-apple-darwin1.2/shp2dig.o] Error 1
Greetings all,
Well I do not now if what I did will cause some problems, but I got v.in.shape to compile by adding a 1 at the switch end:
 <shp2dig.c line 807>  end:
 <shp2dig.c line 808>       1;    (I added this line)
And it compiles, it looks like the same problem as I had before with the empty switch.
Yours,
Jeshua Lacock
Cartographer/Owner
http://SierraMaps.com
http://3dTopoMaps.com
Telephone: (760) 935-4481
If you want to unsubscribe from GRASS Development Team mailing list write to:
minordomo at geog.uni-hannover.de with
subject 'unsubscribe grass5'
