[GRASS5] IRIX binaries....
Justin Hickey jhickey at hpcc.nectec.or.th
Fri Dec 8 03:40:18 EST 2000
Hi all
I'm just trying to get the IRIX binaries compiled and have come across
two modules that had errors and an error in the man page generation.
The two modules were
Module source code not installed: src/misc/m.clump (ignored)
error:
ld32: FATAL 9: I/O error
(/usr/people/guest/grassCVS/grass/src/libes/LIB.mips-sgi-irix6.5/liboptri.a):
No such file or directory
Module source code not installed: src/raster/r.in.gdal (ignored)
error:
ld32: ERROR 33: Unresolved text symbol "GBGetSymbol" -- 1st referenced
by OBJ.mips-sgi-irix6.5/gdalbridge.o.
I haven't installed the gdal library so that is the error for r.in.gdal,
but I have no idea about the m.clump library. the liboptri.a file is
supposed to be a grass library but apparently is not compiled (no other
reference to it in the grass compile output.
For the man page generation I get the following two errors for every man
page:
geqn:fatal error: can't open `/usr/pub/eqnchar': No such file or
directory
gtroff: fatal error: can't open `/usr/lib/tmac/tmac.an': No such file or
directory
The /usr/pub and /usr/lib/tmac directories do not exist on SGI's.
Andreas, do you get the same error message. BTW, trying to run
man -M /.../grass/man d.rast
gives errors concerning "not printable man page".
Any suggestions would be greatly appreciated.
Sincerely,
Jazzman (a.k.a. Justin Hickey)  e-mail: jhickey at hpcc.nectec.or.th
High Performance Computing Center
National Electronics and Computer Technology Center (NECTEC)
Bangkok, Thailand
People who think they know everything are very irritating to those
of us who do.  ---Anonymous
Jazz and Trek Rule!!!
If you want to unsubscribe from GRASS Development Team mailing list write to:
minordomo at geog.uni-hannover.de with
subject 'unsubscribe grass5'
