[GRASS5] configure.in Wants testers...
Markus Neteler neteler at geog.uni-hannover.de
Wed Dec 6 04:58:39 EST 2000
On Wed, Dec 06, 2000 at 10:22:25AM +0700, Justin Hickey wrote:
> Hi Markus and Eric
> Markus Neteler wrote:
> > I propose to keep the old method to get VERSION and NAME_VER in
> > Makefile.in for the beta9 release (simple revert in Makefile.in and
> > removeal of sed expansion on configure[.in]). We have some more time
> > for the stable version to get the new approach working.
> I think I have to agree, I also found a problem with configure. I do not
> install grass under /usr/local (I'm the only one using the CVS version)
> and use the --prefix option. But then GISBASE is not correct, it is
> still /usr/local/grass5. I think that GISBASE needs to be tied with
> prefix. Not sure though.
Hi Justin,
I agree: The GISBASE settings are not correct (it was before).
GISBASE has to be identical with --prefix.
Eric, could you please change that?
Markus
If you want to unsubscribe from GRASS Development Team mailing list write to:
minordomo at geog.uni-hannover.de with
subject 'unsubscribe grass5'
