Fwd: Re: [GRASS5] New MacOS X compilation errors
Andreas Lange Andreas.Lange at Rhein-Main.de
Mon Dec 4 07:56:50 EST 2000
Hi Jeshua,
there are still some odd things with the header. If this header was
generated with the latest configure, Eric should have a look at it for
what i marked.
If you need a quick fix, please try to edit the file manually.
I would recommend to do a "make distclean" (this will remove the
complete Installation and the object and library files) and to re-run
./configure. If the header file does not change, please mail again.
Andreas
Jeshua Lacock wrote:
> Thanks Andreas and Eric!
> After deleting and updating connect.c, it compiles just fine. I still get the error:
> __XErrorFunction
> __XIOErrorFunction
> __Xdebug
> Here's by header file:
> CC                  = cc
why not gcc? Which compiler do you have installed? Is there a Mac OS X
specific compiler installed?
> FC                  =
no Fortran compiler, some modules will not compile.
If you have installed gcc, you should add g77 here.
> LEX                 = flex
> YACC                = yacc
> ARCH                = powerpc-apple-darwin1.2
> MAKE                = make
> prefix              = /usr/local/grass5
> exec_prefix         = /usr/local
> GISBASE             = /usr/local/grass5
> UNIX_BIN            = ${exec_prefix}/bin
> DEFAULT_DATABASE    =
> DEFAULT_LOCATION    =
> COMPILE_FLAGS       = -g -O2
> LDFLAGS             =
No stripping. This is the reason your binary distr. so much bigger than
on e. g. Linux.
Try putting "-s" here and check if it compiles. Your bindist will shrink
to about 40 MB with this.
> DLLIB               =
> XCFLAGS             =  -I/usr/X11R6/include
Try -I/usr/X11/include here if you have this directory. This could be
the reason for the above cited error.
Just a wild guess.
> # XXX - replace SYSV in code with configure results in config.h
> # XXX - need SYSV defined for hpux10
> XLDFLAGS            =
> XINCPATH            =
> XMINCPATH           =
> XLIBPATH            =  -L/usr/X11R6/lib
> XTLIBPATH           =
> XMLIBPATH           =
> XLIB                =  -lSM -lICE -lX11
> XTLIB               = -lXt
> XMLIB               = -lXm
> XEXTRALIBS          =
> COMPATLIB           =
> TERMLIB             =
> CURSES              =  $(TERMLIB) $(COMPATLIB)
> MATHLIB             =
> XDRLIB              =
> ZLIB                = -lz
> #PostgreSQL:
> PQINCPATH           =
> PQLIBPATH           =  -L/usr/lib -L/usr/local/lib
> PQLIB               =
> #ODBC:
> ODBCINC             =
> #Image formats:
> PNGINC              = -I/usr/X11R6/include/ -I/usr/include/gr -I/usr/local/include -I/usr/include
> PNGLIB              = -L/usr/local/lib -L/usr/X11R6/lib -L/usr/lib
> #JPEGINCPATH         = -I/usr/X11R6/include/ -I/usr/include/gr -I/usr/local/include -I/usr/include
> #JPEGLIBPATH         = -L/usr/local/lib -L/usr/X11R6/lib -L/usr/lib
> JPEGINCPATH         =
> JPEGLIBPATH         =
> JPEGLIB             =
> TIFFINCPATH         = -I/usr/local/include
> TIFFLIBPATH         = -L/usr/local/lib
> #openGL files for NVIZ/r3.showdspf
> OPENGLINC           =  -I/usr/local/include/GL -I/usr/X11R6/include/GL
> OPENGLwINC          =
> OPENGLLIB           =  -L/usr/lib -L/usr/local/lib -L/usr/lib/X11 -L/usr/X11R6/lib -lGL
> OPENGLULIB          =
> LGLWM               =
Don't think that NVIZ compiles with this settings. OPENGLULIB is -lGLU
and LGLWM -lGlw on my linux machine.
Is there an OpenGL port for Mac OS X? Did you install Mesa?
> #tcl/tk stuff
> TCLINCDIR           = -I/usr/local/include
> TKINCDIR            = -I/usr/local/include
> TCLTKLIBPATH        = -L/usr/local/lib
> TCLTKLIBS           =
Hmm. TCLTKLIBS is -ltk8.3 -ltcl8.3 on Linux. Did you update the CVS
tree?
Andreas
Andreas Lange, 65187 Wiesbaden, Germany, Tel. +49 611 807850
Andreas.Lange at Rhein-Main.de - A.C.Lange at GMX.net
If you want to unsubscribe from GRASS Development Team mailing list write to:
minordomo at geog.uni-hannover.de with
subject 'unsubscribe grass5'
