[GRASS5] cygwin/windows port
John Huddleston jhudd at lamar.colostate.edu
Mon Dec 4 00:20:02 EST 2000
Mike and Andreas, (Grass list)
I've done the tcl/tk builds for Cygwin before so let me know what
I can upload to Markus' server.
No fifo yet; however, others in Cygwin are working on it.  I was in
touch with Corinna over this topic.  She left it in my lap and I am
finishing up my research for school so I have not had the time to
complete that code.  Do you want me to dig up the references
she sent me?
John Huddleston
----- Original Message -----
To: "grass5" <grass5 at geog.uni-hannover.de>
Sent: Sunday, December 03, 2000 1:48 PM
Subject: Re: [GRASS5] cygwin/windows port
<snip>
> Is there a fifo implementation yet?  My understanding is that none of this
> will work without it.
> > - compile under cygwin, create a new windows graphics DRIVER, use
> > tcltkgrass with the Windows-wish (cygwish).
> > I can start tcltkgrass with the cygwish with some modifications. This
> > would not require to install the X11 system and would run in the windows
> > graphics, which is a big advantage (familiar usage).
> > Writing a graphics driver for windows should not be too complicated for
> > a windows programmer (i can assist as i already wrote a new driver for
> > GRASS). But i don't know if it is possible to compile this driver
> > without MS Visual C++. The headers and API is there, e. g. the cygwish
> > port uses this setup.
> As you say, Cygwin has Windows API headers.  I'm not sure what the driver
> would need that you would need MSVC++ for.  There is also the mingw compiler
> (gcc without Cygwin).
> If the fifo problem is not an issue, please tell me what to do to make a
> driver, and I will think about building one.  I am unsure of how much time I
> will have over the next two months, but I can at least work out what is
> required.
> Cheers
> Mike Thomas.
> If you want to unsubscribe from GRASS Development Team mailing list write to:
> minordomo at geog.uni-hannover.de with
> subject 'unsubscribe grass5'
