[GRASS5] GRASS in Windows95/98
John Huddleston jhudd at lamar.colostate.edu
Mon Jul 31 09:38:32 EDT 2000
Since XGrass was removed you do not need X11R6.4.
Are there Fortran components in Grass?  I can't remember
off hand.  If you develop then yes, otherwise no.
Help me out with the rast.to.vect command.  I cannot find
this in the Grass5 source.   What command are you looking
for?
John
----- Original Message -----
From: BRADLEY HARRISON <bradley.harrison at usa.net>
To: <grass5 at geog.uni-hannover.de>
Sent: Sunday, July 30, 2000 1:05 AM
Subject: [GRASS5] GRASS in Windows95/98
    Do I still need all the other bits such as g77 and X11R6.4 to get GRASS
to
work or all I need is the preconfigured downloads?
   For the moment all I need is to get the rast.to.vect to work. Though I
would like to get a DEM going, but without a monitor it may not be much use.
   yours
   Bradley Harrison
John Huddleston <jhudd at lamar.colostate.edu> wrote:
> hi Bradley,
> Many of the grass data manipulation functions
> are available for windows.  The monitor (or
> display) is not yet available.  I have not tried
> the Tcl/Tk interface yet though.
> You will have to install either the older Cygwin
> B20.1 distribution or the newer version 1.1.2
> in order to get the "unix" commands and DLLs
> required to run grass under Windows.
> The ZIP distribution looks for executables under the
> /usr/local/grass-5.0b area.   Forward slashes only make
> sense when using Cygwin.
> John Huddleston
> If you want to unsubscribe from GRASS Development Team mailing list write
to:
> minordomo at geog.uni-hannover.de with
> subject 'unsubscribe grass5'
____________________________________________________________________
Get free email and a permanent address at http://www.netaddress.com/?N=1
to:
If you want to unsubscribe from GRASS Development Team mailing list write to:
