[GRASS5] Re: G_fatal_error
Markus Neteler neteler at geog.uni-hannover.de
Fri Jun 16 09:34:12 EDT 2000
Hi again,
the G_fatal_error seems to be detected:
Roger wrote:
 I've now narrowed my G_fatal_error() problem down to G_gisinit(); before
 G_gisinit() is called, you can't set the handler function. After
 G_gisinit(), I can reset it to use the R error() and warning() functions,
 jumping back out of interface code to the R prompt safely for fatal
 errors. For now I'm checking environment variables before calling
 G_gisinit, but the longer-term solution is to do an interpreted
 system("g.whatever") and test the value returned by exit(). If the GRASS
 environment is intact and the user mapset is writable, that should be
 enough. The functions in G_gisinit() get to call so many functions which
 fail with G_fatal_error() that trying to guard against them all isn't
 possible. Once past G_gisinit(), we're OK.
Maybe this info is useful for you...
Cheers
 Markus
An embedded message was scrubbed...
Subject: Re: GeoComputation 2000 (fwd)
Date: Fri, 16 Jun 2000 12:20:43 +0000 (   )
Url: http://lists.osgeo.org/pipermail/grass-dev/attachments/20000616/dc0b12b1/attachment.mht
