[GRASS5] commit aborted
James Cameron quozl at us.netrek.org
Mon Jun 12 21:55:39 EDT 2000
On Mon, Jun 12, 2000 at 09:25:51PM +0900, GRASS wrote:
> i'm a new to CVS write access.
> i tried to commit sources, but i got the following error:
> cvs [server aborted]: "commit" requires write access to the repository
> hm... i got cvsid from bernhard at intevation.de.
> what's wrong?
Did you do the original checkout via that cvsid?
Check a Root file somewhere.  They are kept in the CVS subdirectory
under each source directory.  They should include the cvsid.  If not,
the "right" way to fix is to checkout again, but I wouldn't be surprised
to find that you could also just change the CVS/Root file.
James Cameron    mailto:quozl at us.netrek.org     http://quozl.netrek.org/
If you want to unsubscribe from GRASS Development Team mailing list write to:
minordomo at geog.uni-hannover.de with
subject 'unsubscribe grass5'
