[GRASS5] GRASS branching
John Huddleston jhudd at itc.nrcs.usda.gov
Tue May 30 11:48:57 EDT 2000
> John is right, one question remains on my side:
> I assume that we need to use branch tags, as some of the source
> code fixed might get merged into the experimental version and some not.
> Should we not create one stable branch and use one tag for it?
Tagging a branch means that we can export it out for distribution
or check it out for building.   Once the source is checked out with
a tag, we cannot commit any changes.   In order to commit changes
to the HEAD we must first do a 'cvs update -A'.  If we are working
on a branch, we can commit changes.   For branches, remember the
steps are:
tag it as a branch
update your local copy to the branch
edit, compile, link, test
commit changes
merge branch onto the HEAD
John Huddleston
If you want to unsubscribe from GRASS Development Team mailing list write to:
minordomo at geog.uni-hannover.de with
subject 'unsubscribe grass5'
