[GRASS5] Digitizer drivers in v.digit
Rich Shepard rshepard at appl-ecosys.com
Thu May 11 09:06:31 EDT 2000
On Thu, 11 May 2000, Justin Hickey wrote:
> There were "unused" files in the v.digit directory as well, and we wanted to
> delete these (after all, I like to clean up code when I can :). Markus has
> moved them to an unused directory in CVS and I recompiled v.digit without them
> and all went well (Markus, the new directory "unused" did not show up when I
> did the cvs update, is this a problem?). So in summary, we are confused about
> how this apparently extra code is used by digitizers and are they even
> necessary anymore. We would appreciate any ideas you may have concerning
> digitizers and v.digit code. Unfortunately, we do not have a digitizer so we
> cannot even run our own tests.
Jazzman,
  Uh, oh! Not good. I have a Hitachi HDG-2436 table which is reputed (in the
source code) to be supported). I am willing to test your code for you. I
bought the digitizer (used, of course) specifically for use with GRASS. When
you think you have a working version, send it to me (off-list) and I'll hook
up the digitizer and run some tests.
  This will also force me to learn how to initialize the board and use it
within GRASS. Ergo, mutual benefit.
Rich
Dr. Richard B. Shepard, President
                       Applied Ecosystem Services, Inc. (TM)
              Making environmentally-responsible mining happen. (SM)
            2404 SW 22nd Street | Troutdale, OR 97060-1247 | U.S.A.
 + 1 503-667-4517 (voice) | + 1 503-667-8863 (fax) | rshepard at appl-ecosys.com
If you want to unsubscribe from GRASS Development
Team internal mailing list write to:
minordomo at geog.uni-hannover.de with
subject 'unsubscribe grass5'
length: 2519
max: 0
