[GRASS5] CVS read/write access up again (was: [GRASS5] CVS read/write access down)
John Huddleston jhudd at itc.nrcs.usda.gov
Wed May 10 13:18:41 EDT 2000
Place the perl script into the CVSROOT directory
and we can all add to it.
John Huddleston
----- Original Message -----
From: Markus Neteler <neteler at geog.uni-hannover.de>
To: <grass5 at geog.uni-hannover.de>
Sent: Wednesday, May 10, 2000 11:05 AM
Subject: Re: [GRASS5] CVS read/write access up again (was: [GRASS5] CVS
> On Wed, May 10, 2000 at 11:50:14AM -0400, Eric Mitchell wrote:
> > One recommendation on the CVS commits list:
> > Set the reply-to header on the message to the
> > grass development list.  This makes it easier
> > to discuss any issues that might arise with a
> > particular commit.
> Eric,
> a good idea.
> But: I do not know PERL enough...
> It needs to be implemented to set the "reply_to"
> with an configuration parameter in config file.
> A few things can be set in minordomo, but not
> reply_to. In case you could help, I will send
> the minordomo.pl to you.
> Markus
> If you want to unsubscribe from GRASS Development
> Team internal mailing list write to:
> minordomo at geog.uni-hannover.de with
> subject 'unsubscribe grass5'
> length: 1471
> max: 0
length: 2890
max: 0
