[GRASS5] CVS read/write access up again (was: [GRASS5] CVS read/write access down)
Markus Neteler neteler at geog.uni-hannover.de
Wed May 10 13:05:41 EDT 2000
On Wed, May 10, 2000 at 11:50:14AM -0400, Eric Mitchell wrote:
> One recommendation on the CVS commits list:
> Set the reply-to header on the message to the
> grass development list.  This makes it easier
> to discuss any issues that might arise with a
> particular commit.
Eric,
a good idea.
But: I do not know PERL enough...
It needs to be implemented to set the "reply_to"
with an configuration parameter in config file.
A few things can be set in minordomo, but not
reply_to. In case you could help, I will send
the minordomo.pl to you.
Markus
If you want to unsubscribe from GRASS Development
Team internal mailing list write to:
minordomo at geog.uni-hannover.de with
subject 'unsubscribe grass5'
length: 1471
max: 0
