[GRASS5] New initialization code
Robert Lagacé lagace at echo.grr.ulaval.ca
Thu Nov 30 11:24:19 EST 2000
"Eric G . Miller" wrote:
> On Thu, Nov 30, 2000 at 04:03:18PM +0700, Justin Hickey wrote:
> > Hi Robert
> > Robert Lagacé wrote:
> > > We need to know that, on all SVR4 systems such as HP-UX 10 and 11, all
> > > non OS software should be installed under /opt/.  So, Grass would be
> > > in /opt/grass/bin/ and appropriate directories under /opt/grass/.
> > > System admin is simplified because everything is under one directory.
> > > I will test the new configure under HP-UX when I will have time (in
> > > two weeks).
> > Hmm. Another "standard" local program install directory. Arrrgh. Well,
> > the only thing I can think of is that we use some way in configure.in to
> > detect HP-UX. What is the output of "uname -s" for HP's? If we can't get
> > it installed in /opt by default, then you will have to use the --prefix
> > and --bindir options for configure.
> > By the way, what is the bin directory that appears in user's PATH's,
> > /opt/bin/?
> > Thanks in advance for the test!!
> I'd advocate against worrying about this.  This is what the --prefix=
> directive to configure is for.  Same with --bindir.
I agree.
> Eric G. Miller <egm2 at jps.net>
> If you want to unsubscribe from GRASS Development Team mailing list write to:
> minordomo at geog.uni-hannover.de with
> subject 'unsubscribe grass5'
Robert Lagacé, professeur
Pavillon Comtois
Université Laval
Ste-Foy, Québec, G1K 7P4
tel : (418)-656-2131#2276
Fax : (418)-656-3723
E-mail : lagace at grr.ulaval.ca
