[GRASS5] New initialization code
Eric G . Miller egm2 at jps.net
Wed Nov 29 00:06:19 EST 2000
One thing you should consider too, is checking if the $DISPLAY
environment variable is set.  Could be a user is running in a console
only mode (console, telnet, ssh with no X forwarding).  Haven't a clue
about Windows in this regard.
Eric G. Miller <egm2 at jps.net>
If you want to unsubscribe from GRASS Development Team mailing list write to:
minordomo at geog.uni-hannover.de with
subject 'unsubscribe grass5'
