[GRASS5] Win32 compile with cygnus ...
Eric Mitchell emitchell at altaira.com
Mon Nov 27 11:09:49 EST 2000
The translation of the cygwin filename,
	//f/source/cvsroot/grass/src/CMD/generic/gmake.sh
into windows-speak is,
	f:\source\cvsroot\grass\src\CMD\generic\gmake.sh
It is indeed a cygwinification of the windows environment.
Justin Hickey wrote:
> Hello Mike
> Mike Thomas wrote:
> > There is a gmake5 script in /usr/local/bin:
> > SRC=//f/source/cvsroot/grass/src
> > CMD=//f/source/cvsroot/grass/src/CMD
> > HEADER=head.i586-pc-cygwin
> > HASX=yes
> > HASMotif=no
> > MAKE=make
> > . //f/source/cvsroot/grass/src/CMD/generic/gmake.sh
> I think I may have found the problem. It depends on your setup and
> cygwin, but these two slashes on a windows machine may be interpreted
> (such as in Tcl) as a network file where f would be the machine name. I
> assume that f is not a machine name, thus, cygwin may be trying to find
> the file on a machine named f instead of the directory f. Thus, you are
> getting the error you mentioned in your previous mail (it has the same
| Eric B. Mitchell         mailto:emitchell at altaira.com |
| tel: (301) 809 - 3534    Altair Aerospace Corporation |
| tel: (800) 7 - ALTAIR    4201 Northview Dr. Suite 410 |
| fax: (301) 805 - 8122    Bowie, MD  20716             |
              ,___
          /"\  / o=\  /"""---===/
         /   \_/  \__/   ---===/
         |    //\   || /""TT""/ //\   || ||""\
         |   //  \  ||    ||   //  \  || ||__/
         |  //--==\ |L--/ ||  //--==\ || || "=,
           \____---===/
If you want to unsubscribe from GRASS Development Team mailing list write to:
minordomo at geog.uni-hannover.de with
subject 'unsubscribe grass5'
