[GRASS5] configure.in Wants testers...
Justin Hickey jhickey at hpcc.nectec.or.th
Mon Nov 27 05:26:14 EST 2000
Hi Eric, and Markus
Markus Neteler wrote:
> On Sun, Nov 26, 2000 at 02:10:35PM -0800, Eric G . Miller wrote:
> > Do we think configure.in is close enough at this point to replace
> > the configure script currently in CVS with a new one generated from
> > configure.in?  There's some breakage right now because some
> > variables have been defined elsewhere that aren't handled by the
> > current configure script.
> > Any objections?
> Hi Eric,
> the only objection is that
> TCLTKLIBS
> is not yet set. If you would manage to fix this, it can be replaced.
Unfortunately I found another problem. I updated from CVS and then ran
make distclean. Then I ran autoconf and make install and then found
these messages:
UNIX_BIN=/usr/people/guest/grassCVS/grass/bin SRC= MAKE=make
NAME_VER=`cat /src/CMD/VERSION | head -1 | sed 's/\..*//'`
GISBASE=/usr/people/guest/grassCVS/grass MACHINENAME=`uname -n` /bin/sh
src/CMD/generic/CREATE_GMAKE.sh mips-sgi-irix6.5
Cannot open /src/CMD/VERSION: No such file or directory
        /bin/sh /src/CMD/generic/is64bit.sh mips-sgi-irix6.5
/bin/sh: /src/CMD/generic/is64bit.sh:  not found
*** Error code 127 (bu21)
You will notice that SRC variable is empty, thus causing paths for
things in the grass source tree to bigin with /. Checking the Makefile
indicates that SRCDIR=$(pwd) which in this case is empty. I don't know
if this is only happening on SGI's or not. Markus, did you try a make
install on Linux?
Anyway, I hope this helps.
Sincerely,
Jazzman (a.k.a. Justin Hickey)  e-mail: jhickey at hpcc.nectec.or.th
High Performance Computing Center
National Electronics and Computer Technology Center (NECTEC)
Bangkok, Thailand
People who think they know everything are very irritating to those
of us who do.  ---Anonymous
Jazz and Trek Rule!!!
If you want to unsubscribe from GRASS Development Team mailing list write to:
minordomo at geog.uni-hannover.de with
subject 'unsubscribe grass5'
