[GRASS5] GRASS module descriptions (3)
John Reid jgreid at uow.edu.au
Thu Nov 23 23:24:50 EST 2000
hi,
Just a thought - POSIX compliant command line options are of the format
--option (I think this is right - case of monkey see, monkey do).  how
is the -- handled by the parser?  No linux at work so can't test :-(
cheers,
john
Michel Wurtz wrote:
> Markus Neteler wrote:
> > I have added "help" and "-help" parameters to all scripts in
> > src/scripts/contrib where it wasn't implemented yet
> After verification, the parameter's parser in C looks only at the
> first letter after the dash.  Hence you can type :
> command help
> command -help
> command -h
> command -here_is_anything_you_want
> and allways get the help printed
> > If you want to unsubscribe from GRASS Development Team mailing list write to:
> > minordomo at geog.uni-hannover.de with
> > subject 'unsubscribe grass5'
john reid                                  e-mail john_reid at uow.edu.au
technical officer                                room G02, building 41
school of geosciences                           phone +61 02 4221 3963
university of wollongong                          fax +61 02 4221 4250
uproot your questions from their ground and the dangling roots will be
seen.  more questions!
                                                       -mentat zensufi
apply standard disclaimers as desired...
