[GRASS5] MacOS X binaries dependencies
Eric G . Miller egm2 at jps.net
Thu Nov 23 12:20:43 EST 2000
On Thu, Nov 23, 2000 at 03:24:04PM +0700, Justin Hickey wrote:
> Hi Jeshua
> Jeshua Lacock wrote:
> > Thanks Justin!  It turns out that (for whatever reason)  grass was
> > installed at /usr/local/grass5.
> You're welcome.
> > I made a symbolic link  /usr/local/grass-5.0b  ->  /usr/local/grass5
> > and it works!!
> > (Markus: can you please add this to the installation instructions?:
> > cd /usr/local; ln -s grass-5.0b grass5;)
> Actually, we need to find where the grass-5.0b is coming from. We made a
> decision that it would be grassx where x is the current major version
> number to simplify coding and decrease user confusion.
> Markus, do you know where the grass-5.0b is coming from?
It's coming from PREFIX= in the configure script. You can change it with
--prefix=DIR.  Changing the default to grass5 is a simple matter.
Eric G. Miller <egm2 at jps.net>
If you want to unsubscribe from GRASS Development Team mailing list write to:
minordomo at geog.uni-hannover.de with
subject 'unsubscribe grass5'
