[GRASS5] [GRASS-bugs] Bugreport GRASS 5
Andreas Lange Andreas.Lange at Rhein-Main.de
Tue Nov 21 19:16:44 EST 2000
this is fixed now.
Only a missing else statement.
But only the status of the _last_ expression is returned. Else the
module must exit on any error, what is not desirable.
Andreas
aaime at comune.modena.it wrote:
> Below is the result of your feedback form.  It was submitted by
>  (aaime at comune.modena.it) on Monday, November 20, 2000 at 11:07:02
> subject: Bugreport GRASS 5
> platform: Linux/Intel
> vendor: RedHat
> cputype: Intel (i486, i586, pentium ...)
> grassversion: Linux/Intel binaries
> cvsyesno: -- select --
> module: r.mapcalc
> bugreport: r.mapcalc exit status is always the same (0) even if it found some errors in the expression. That's not good if you use it in a script!
> I guess it should at least report an error status if the last expression wasn't correct or it found any other run time problem.
> compiler: -- select --
> REMOTE_HOST: comnet.comune.modena.it
> If you want to unsubscribe from grass-bugs
> mailing list write to:
> minordomo at geog.uni-hannover.de with
> subject 'unsubscribe grass-bugs'
> If you want to unsubscribe from GRASS Development Team mailing list write to:
> subject 'unsubscribe grass5'
Andreas Lange, 65187 Wiesbaden, Germany, Tel. +49 611 807850
Andreas.Lange at Rhein-Main.de - A.C.Lange at GMX.net
