[GRASS5] MacOS X binaries dependencies
Jeshua Lacock jeshua at SierraMaps.com
Thu Nov 23 02:15:17 EST 2000
Hi all,
I have installed the MacOS X beta 8 binaries on an other (clean) machine to test it and found that it was dependent on:
  wish8.0, tclsh8.0 and the /usr/local/lib tcl & tk files.
After I tarred the above files and directories, tcltkgrass will start with no errors, however when I go to start a monitor it acts like its going to work, but does not produce a monitor.
d.mon says:
Sorry, </usr/local/grass-5.0b/dev/fifo.1a> not available
Have GRASS administrator check etc/monitorcap file
What other files might tcltkgrass may be dependent on??
Jeshua Lacock
Telephone: (760) 935-4481
If you want to unsubscribe from GRASS Development Team mailing list write to:
minordomo at geog.uni-hannover.de with
subject 'unsubscribe grass5'
