[GRASS5] Re: bug in configure routine
Jan-Oliver Wagner jan at intevation.de
Tue Nov 21 10:16:21 EST 2000
On Tue, Nov 21, 2000 at 11:15:10PM +0900, GRASS wrote:
> Hmm, yes you're right. You can use --with-bindir instead of --bindir.
Yes, I have done that to compile GRASS :-)
> $bindir, created by --bindir, is not used though defined.
> $BINDIR, created by --with-bindir, is used instead.
> So i suggest to remove --bindir and other unused options of configure.
> Any objection?
The configure environment should just behave in a general way
(as it is widely used) and be consistent.
Jan-Oliver Wagner               http://intevation.de/~jan/
Intevation GmbH	              	     http://intevation.de/
FreeGIS	                               http://freegis.org/
If you want to unsubscribe from GRASS Development Team mailing list write to:
minordomo at geog.uni-hannover.de with
subject 'unsubscribe grass5'
