[GRASS5] Win32 compile with cygnus ...
Mike Thomas mthomas at gil.com.au
Tue Nov 21 03:47:47 EST 2000
Hi all.
> I want to underline that i started the cygwin compile thing only because
> i had the impression that we need to solve the windows problems before
> we publish the stable version. Otherwise Windwos users will curse on
> GRASS and on Unix software generally. I hope to get the X11R6 for
> Windows on CD to compile the X windows part.
> The windows port still needs a lot of user land testing.
Thanks for the support Andreas.
Here's another problem with a clean cvs updated  and ./configured grass
source directory - gmake5.0 is not found even though it is there (maybe a
Cygwin problem?):
mike at SNOWPEA //f/source/cvsroot/grass
$ make install
test -d /usr/local/grass-5.0b || mkdir -p -m 755 /usr/local/grass-5.0b
test -d src/CMD/next_step || mkdir -p src/CMD/next_step
test ! -f src/CMD/head/head || mv src/CMD/head/head
UNIX_BIN=/usr/local/bin SRC=//f/source/cvsroot/grass MAKE=make NAME_VER=`cat
/CMD/VERSION | head -1 | sed 's/\..*//'` GISBASE=/usr/local/grass-5.0b
ME=`uname -n` /bin/sh src/CMD/generic/CREATE_GMAKE.sh i586-pc-cygwin
/bin/sh //f/source/cvsroot/grass/src/CMD/generic/is64bit.sh i586-pc-cygwin
Now proceed with make install
ke5.0 HEADER=head.i586-pc-cygwin MAKE=make /bin/sh src/CMD/generic/GISGEN.sh
//f/source/cvsroot/grass/src/CMD/gmake5.0: not found
make: *** [do-install] Error 1
If you want to unsubscribe from GRASS Development Team mailing list write to:
minordomo at geog.uni-hannover.de with
subject 'unsubscribe grass5'
