[GRASS5] Mac OS X r.* errors
System Administrator jeshua at SierraMaps.com
Tue Nov 14 23:44:06 EST 2000
Greetings,
I just installed OS X on my main machine (500 mhz G4) and it compiled Grass in about 45 minutes (Now I can justify buying a dual-processor box,  it would compile in less then 25 minutes)!   : D
I pre-installed and compiled the PNG, TIFF, JPEG libraries, and all of the modules that failed to compile before installing their dependent libraries still fails to compile.
I would really like to get these raster formats working (at least TIFF) before I upload the binaries.
Note that I am unable to open files in GIF format.  If I click on the 'RUN' module it states that "Couldn't execute 'r.in.gif': no such file or directory".  Sure enough, the module is not to be found. Upon inspection of the install logs, I do not see any gif modules that were compiled - ignored or successful. There is a r.in.gif file in the src/raster directory.
The PNG module does not state any useful error messages, however the TFF module does.
Here is the log output for the TIFF module, followed by the PNG module.
/usr/src/grass/src/raster/r.tiff
  mkdir OBJ.powerpc-apple-nextstep3
  make -f OBJ.powerpc-apple-nextstep3/make.rules
rm -f OBJ.powerpc-apple-nextstep3/r.in.tiff.o
cc -g -O2     -I/usr/src/grass/src/include  -c r.in.tiff.c
mv r.in.tiff.o OBJ.powerpc-apple-nextstep3/r.in.tiff.o
cc  -o /usr/local/grass-5.0b/etc/bin/contrib/cmd/r.in.tiff OBJ.powerpc-apple-nextstep3/r.in.tiff.o /usr/src/grass/src/libes/LIB.powerpc-apple-nextste
p3/libgis.a  -L/usr/local/lib -L/usr/X11R6/lib -L/usr/lib -ltiff -lz
/usr/bin/ld: table of contents for archive: /usr/local/lib/libtiff.a is out of date; rerun ranlib(1) (can't load from it)
GISGEN failure at STEP: src/raster/r.tiff
__________________________________________________________
GISGEN: src/raster/r.in.png - Tue Nov 14 16:12:52 PST 2000
/usr/src/grass/src/raster/r.in.png
rm -f OBJ.powerpc-apple-nextstep3/r.in.png.o
cc -g -O2  -I/usr/X11R6/include/ -I/usr/include/gr -I/usr/local/include -I/usr/include -I/usr/src/grass/src/include  -c r.in.png.c
GISGEN failure at STEP: src/raster/r.in.png
Cheers,
Jeshua Lacock
(760) 935-4481
Cartographer/Owner
http://SierraMaps.com
http://3dTopoMaps.com
If you want to unsubscribe from GRASS Development Team mailing list write to:
minordomo at geog.uni-hannover.de with
subject 'unsubscribe grass5'
