[GRASS5] list of modules with interface problems
Jan-Oliver Wagner jan at intevation.de
Mon Oct 30 04:07:02 EST 2000
Hi Andreas,
On Sun, Oct 29, 2000 at 07:34:55PM +0100, Andreas Lange wrote:
> Some modules do produce "garbage" output with the
> "--interface-description" flag, which makes the output fail parsing with
> a xml parser. For your information here the list of modules:
> {m.lulc.USGS} {Mlulc.read} {Mlulc.USGS} {v.surf.rst} {v.out.atlas}
> {v.in.dxf2} {v.in.dxf} {v.in.atlas} {s.surf.rst} {r.weighted.cn}
> {r.resamp.rst} {r.random} {r.out.rlc} {r.mapcalc} {r.flow} {r.colors}
> {m.in.stf1.db3} {m.in.pl94.db3} {i.tape.mss.h} {i.gensigset} {g.list}
> {d.where} {d.rhumbline} {d.paint.labels} {d.colormode}
thanks for testing!
It seems that most people like the idea of an xml-based user interface
description for GRASS commands.
So I will now complete the xml output ('multiple' etc.), finish the
corresponding dtd and check for problems.
Cheers
	Jan
Jan-Oliver Wagner               http://intevation.de/~jan/
Intevation GmbH	              	     http://intevation.de/
FreeGIS	                               http://freegis.org/
If you want to unsubscribe from GRASS Development Team mailing list write to:
minordomo at geog.uni-hannover.de with
subject 'unsubscribe grass5'
