[GRASS5] Re: [caj78500@pop16.odn.ne.jp: Bugreport GRASS 5]
Radim Blazek Radim.Blazek at dhv.cz
Sun Oct 29 11:13:52 EST 2000
> Hi David, hi all
> [I switch to the devel list]
> On Fri, Oct 27, 2000 at 03:02:26PM +0000, David D Gray wrote:
> > Hi Markus
> > This seems to be a `snap' problem. I've seen the same thing myself.
> > Occasional grid cells don't show correct topology when using v.mkgrid. I
> > think it must be because of micro-misalignments during the build
> > process. A very small snap coefficient has always fixed it. You can't
> > call this a feature, so it is probably a bug. But it is very difficult
> > to secure exact coincidence of points without using tolerance limits of
> > some kind (impossible - if different platforms have different fp
> > behaviour). So the answer is probably to create a default snap radius of
> > a very small amount, say 10e-6 * <ground resolution> (what do you think
> > of this scale in general mapping terms - could it be a problem?), in
> > v.support, though it would still be possible to over-ride it with
> > threshold=0.
> ..mhhh, difficult question. I always hesitate to have auto-correction
> oof data, but in this case it seems to be required. The question is
> what is the smallest usable value for <factor> * <ground resolution>:
> Would 10e-9 do as well?
> How to other GIS packages fix such a problem (they will have it, too).
> > At some point we need to thoroughly overhaul v.build. This is now the
> > commonest source of problems. I don't think there's anything
> > release-critical that can't be worked around - as here.
> Other developers, what's your recommendation/experience?
> Kind regards
>  Markus
I agree that it is bug but in v.mkgrid and not in v.build. (I don't say v.build doesn't have any bug.)
v.mkgrid calculates x once as:
x_len = length/3.;
x_cols = cols*3.;
for (){
  next_x = x + x_len;
and then:
for(){
  x += length;
It is obvious that lines are not connected.
I am strongly against possible building areas from dirty data. It could have some dangerous
consequences:
- data built and displayed correctly in GRASS exported to some other SW will not work.
- we could not rely on areas in GRASS at all. For example analysis between point and areas
   could find no area or more areas for points near dirty connections:
                 |                                                  Legend:
  area1       |       area2                                    -- boundary
        +    point
------    +    --------                               |<----->|   snapping tolerance
  area3       |       area4
Areas would be built correctly but point is outside. You could see point in
place correctly covered by areas on monitor.
Radim
If you want to unsubscribe from GRASS Development Team mailing list write to:
minordomo at geog.uni-hannover.de with
subject 'unsubscribe grass5'
