[GRASS5] Re: CREATE_GMAKE.sh for multiple architectures
Markus Neteler neteler at geog.uni-hannover.de
Fri Oct 27 07:13:46 EDT 2000
Hi all,
from Bev I received a suggestion for src/CMD/head/head:
On Thu, Oct 26, 2000 at 01:02:18PM -0700, Bev Wallace wrote:
> Markus,
> I install Grass for three architectures (Sol 2.6, Sol 2.7, and Irix 6.5)
> from one set of source code.  I set both --prefix and --with-bindir for
> each architecture.  The problem is that gmake5 in the bindir will only
> work for the architecture that was configured last.
> I made a simple change to CMD/generic/CREATE_GMAKE.sh that saves the
> "head" file for each architecture and uses it in the gmake5 script.
> This means that I can run gmake5 from each bindir without re-running
> configure.
> I have attached my CREATE_GMAKE.sh.  I got the $ARCH sed command from
> CMD/generic/gmake.sh.
> I hope you can use this in the official version of Grass.
> Regards, Bev Wallace
> Bev Wallace
> Lockheed Martin Missiles & Space, Sunnyvale, CA
> Email:  beverly.t.wallace at lmco.com
> Phone:  (408) 756-0494
I have tried, it works o.k. for me. Is it alright with
all to make this modification?
First the file src/CMD/head/head is generated,
then moved to src/CMD/head/head.$(ARCH)
The gmake5 is taking care of the new head.$(ARCH).
If no objections, I will upload to CVS.
Kind regards
 Markus
Dipl.-Geogr. Markus Neteler *  University of Hannover
Institute of Physical Geography and Landscape Ecology
Schneiderberg 50 * D-30167 Hannover * Germany
Tel: ++49-(0)511-762-4494  Fax: -3984
If you want to unsubscribe from GRASS Development Team mailing list write to:
minordomo at geog.uni-hannover.de with
subject 'unsubscribe grass5'
