[GRASS5] r.to.sites: change proposal for -a
Markus Neteler neteler at geog.uni-hannover.de
Tue Oct 24 10:00:39 EDT 2000
Hi all,
a proposal for r.to.sites:
Currently when converting raster data to sites format you
get a list like this:
3571556.25|5775981.25|#106
3571731.25|5775981.25|#123.8
3572243.75|5775981.25|#109.5
3570556.25|5775968.75|#132.5
Here we have two problems:
 - #cat may be INT only
 - usually you want %doubles format in sites list
I propose a change for r.to.sites:
remove this flag:
  -a   Output as decimal attribute rather than cat
and add a new one:
  -c Output as cat rather than decimal attribute
Would that be o.k.? If not we would need at least a test
if the raster map is an FP map and generate doubles in sites list then.
Above format is invalid.
If there are no objections I would change the flag in r.to.sites
and the HTML page, too.
Kind regards
 Markus
If you want to unsubscribe from GRASS Development Team mailing list write to:
minordomo at geog.uni-hannover.de with
subject 'unsubscribe grass5'
