[GRASS5] Debugging modules ...
Markus Neteler neteler at geog.uni-hannover.de
Sun Oct 22 14:06:42 EDT 2000
Hi Andreas, Eric, all,
if you finally have some receipe to debug GRASS modules,
please add a short text to CVS for the others...
Thanks in advance
 Markus
On Sat, Oct 21, 2000 at 10:18:56AM -0700, Eric G . Miller wrote:
> On Sat, Oct 21, 2000 at 09:38:20AM +0000, David D Gray wrote:
> > This is mainly what I do (do you find the mouse behaviour a bit
> > quirky..?)
> That's an understatement (DDD is a little buggy itself).
> > In fact I have a whole tree with these flag options for
> > debugging : only too often you have to trace into library calls. But I
> > have had to run ddd through the GRASS environment, eg through the
> > terminal that opens GRASS. It mostly gets confused when you try to trace
> > into a forked process - do you have any insights on this?
> Yea, forgot to mention about having to run it from an active GRASS
> session.  As far as forked processes go, must admit I don't know.  I
> don't use debuggers very often.
> /bin/sh ~/.signature:
> Command not found
> If you want to unsubscribe from GRASS Development Team mailing list write to:
> minordomo at geog.uni-hannover.de with
> subject 'unsubscribe grass5'
Dipl.-Geogr. Markus Neteler *  University of Hannover
Institute of Physical Geography and Landscape Ecology
Schneiderberg 50 * D-30167 Hannover * Germany
Tel: ++49-(0)511-762-4494  Fax: -3984
