[GRASS5] Debugging modules ...
Eric G . Miller egm2 at jps.net
Sat Oct 21 13:18:56 EDT 2000
On Sat, Oct 21, 2000 at 09:38:20AM +0000, David D Gray wrote:
> This is mainly what I do (do you find the mouse behaviour a bit
> quirky..?)
That's an understatement (DDD is a little buggy itself).
> In fact I have a whole tree with these flag options for
> debugging : only too often you have to trace into library calls. But I
> have had to run ddd through the GRASS environment, eg through the
> terminal that opens GRASS. It mostly gets confused when you try to trace
> into a forked process - do you have any insights on this?
Yea, forgot to mention about having to run it from an active GRASS
session.  As far as forked processes go, must admit I don't know.  I
don't use debuggers very often.
/bin/sh ~/.signature:
Command not found
If you want to unsubscribe from GRASS Development Team mailing list write to:
minordomo at geog.uni-hannover.de with
subject 'unsubscribe grass5'
