[GRASS5] vector bug?
Andreas Lange Andreas.Lange at Rhein-Main.de
Thu Oct 19 11:56:39 EDT 2000
i discovered a problem with a vector file. As i have no clue what is
happening, i'll describe the symptoms here:
global dataset from hannover server, untarred and chown'ed to my account
(permissions are correct):
d.vect coastlines says:
file has been modified, you MUST first run "v.support"
next:
running v.support on coastlines:
i filled in all values...
Orig. Scale is -1067646976 (overflow?)
ERROR: could not build vector file.
Same with v.out.ascii.
can not fix this. grass4.3 displays the file without problems, my other
vector files are still intact.
cu,
Andreas
Andreas Lange, 65187 Wiesbaden, Germany, Tel. +49 611 807850
Andreas.Lange at Rhein-Main.de - A.C.Lange at GMX.net
If you want to unsubscribe from GRASS Development Team mailing list write to:
minordomo at geog.uni-hannover.de with
subject 'unsubscribe grass5'
