[GRASS5] WWW-GRASS follow up
Roberto Micarelli mi.ro at iol.it
Sun Oct 15 13:29:33 EDT 2000
On dom, 15 ott 2000, Markus Neteler wrote:
> Hi Roberto,
> On Sat, Oct 14, 2000 at 09:59:27PM +0200, roberto micarelli wrote:
> <snip>
> > I'm working in loading PostgreSQL with data read from e00 tables (I've cloned
> > m.in.e00 and changed to my needs). I mean, not only attributes but also geometry
> as you have already modified m.in.e00 to read attributes into
> PostgreSQL, could you add this to the CVS? Attribute storage into
> PG is quite important. Geometry storage is another point, I am just
> thinking of attributes. It would be great to have such feature in
> GRASS 5.0stable (comparing to v.in.shape). Do you think that's feasible
> for the next days (as GRASS 5.0stable  shall be published very soon)?
> Thanks
>  Markus Neteler
'very soon' means that I can give a different program to load INFO tables in PostgreSQL.
Leaving the geometry import task to m.in.e00
In fact I've modified m.in.e00 very hard, loosing the digs load functinality  and making it
generate a PG table for each INFO table. This task is done in a more general way than
the original and non standard tables can be read and generated too.
I've done it for test purposes of Postgres with my datastores. If you think it can be enought
I can proceed.
Roberto
If you want to unsubscribe from GRASS Development Team mailing list write to:
minordomo at geog.uni-hannover.de with
subject 'unsubscribe grass5'
