[GRASS5] Linux KDE: GRASS monitor does not refresh
Markus Neteler neteler at geog.uni-hannover.de
Fri Oct 13 14:12:59 EDT 2000
Roberto,
mhhh, it's still not perfect. At least the background is not copied into
the monitor any more but the contents (site list crosses) still
dissappear.
I will try your -wm now...
Markus
On Fri, Oct 13, 2000 at 06:18:37PM +0100, Markus Neteler wrote:
> > > Hi all,
> > > recently I switched to KDE 1.1.2 (SuSe 7) and have the problem,
> > > than the GRASS monitor does not refresh if hidden by another window
> > > and put back into foreground. It remains black.
> > > Does anyone have an idea how to fix this?
> > > Thanks!
> > >  Markus
> > It seems exposure events not being generated.
> > One trivial way could be to enable backing-store in the X server
> > (more memory needed by X)
> > In /etc/X11/xdm/Xserver
> > change a line like this
> > :0 local /usr/X11R6/bin/X
> > to
> > :0 local /usr/X11R6/bin/X -wm
> The "backing-store" thing was the right idea. I had to
> add
>   Option        "backingstore" "on"
> to the
>   Section "Device"
> of /etc/X11/XF86Config as I am using Xfree4. Now it works o.k.
> Thanks a lot
>  Markus
If you want to unsubscribe from GRASS Development Team mailing list write to:
minordomo at geog.uni-hannover.de with
subject 'unsubscribe grass5'
