[GRASS5] Display bug with tcltkgrass
Eric G . Miller egm2 at jps.net
Thu Oct 12 22:20:58 EDT 2000
On Thu, Oct 12, 2000 at 06:51:16AM -0500, Tim Cera wrote:
> On my laptop, the tcltkgrass menu does not display fully.  I can only
> see the 'ui' of the 'Quit' command and the sub-menus that pop-up to the
> side do not display properly for those menu choices on the right side of
> the menu bar.
Try changing the fonts. The command is on the left side.  But, given the
width of the menu bar, perhaps it should be split?
/bin/sh ~/.signature:
Command not found
If you want to unsubscribe from GRASS Development Team mailing list write to:
minordomo at geog.uni-hannover.de with
subject 'unsubscribe grass5'
