[GRASS5] CVS - grass compilation on linux and IRIX
Andreas Lange Andreas.Lange at Rhein-Main.de
Thu Oct 12 12:47:01 EDT 2000
Hi 2 all,
on linux my last compile did'nt work because of the mentioned problems
with $(BIN)/grass5. I hope that a new CVS update solves this. Please
check if your updated configuration still works, as this sets me up
another day with my work (testing the coordinate conversion library).
On Irix i can now compile, the culprit was IMHO that the SGI make was in
my path before the GNU make, so that it didn't work as expected.
But the tiff/png and tcl/tk libraries are not found by configure. So a
whole bunch of modules is not build. I'll send the error.log another
time.
One suggestion: could someone modify the make targets in a way that
makes it possible to delete all object files and libraries and re-run
configure without deleting the binary installation? Or what is the name
of this target?
cu,
Andreas
Andreas Lange, 65187 Wiesbaden, Germany, Tel. +49 611 807850
Andreas.Lange at Rhein-Main.de - A.C.Lange at GMX.net
If you want to unsubscribe from GRASS Development Team mailing list write to:
minordomo at geog.uni-hannover.de with
subject 'unsubscribe grass5'
