[GRASS5] GRASS 5 cleanup: HTML/MAN pages
Markus Neteler neteler at geog.uni-hannover.de
Wed Oct 11 15:19:47 EDT 2000
Hi all,
I have removed all local HTML/MAN files as their location
is now:
html/html/
This prevents us from having concurrent man pages. Certainly
I have done comparisons (and partly updates in html/html)
before removing from CVS.
Some 60 file are affected.
In case you add a module or update a module, put/update the
docs in HTML format in html/html/ directory. The MAN format will
be generated by a script (if working o.k. the entire man/ and
cat/ sections can be removed from CVS).
In GRASS 5.1devel we might change to XML or something else.
Hope this is alright with you
 Markus
If you want to unsubscribe from GRASS Development Team mailing list write to:
minordomo at geog.uni-hannover.de with
subject 'unsubscribe grass5'
