[GRASS5] Announce: NVIZ Update
Markus Neteler neteler at geog.uni-hannover.de
Mon Oct 2 12:44:03 EDT 2000
Forwarded from Bob:
(and included into CVS by Markus):
On Mon, Oct 02, 2000 at 09:03:35AM -0300, Bob Covill wrote:
> Markus,
> I have attached a tar file containing the niviz updates for TIFF
> support. The tar file should be unpacked in
> $GISBASE/src.contrib/GMSL/NVIZ2.2. The archive contains updates for the
> src directory to create a new NVIZ program entitled Nwrite_tif. A new
> Gmakefile template is included with libtiff added to the compile flags.
> This requires configure be re-executed from the NVIZ2.2 src directory to
> re-create the new Gmakefile.
> The archive also contain three updated TCL scripts, that incorporate the
> three image formats. The image dump button now goes to cascade menu
> where the user can select to dump to an RGB, PPM, or TIFF. In the
> animation menus, I added radiobuttons to the final dump menus. When
> setting base name for dump files, the file type can also be set. The
> default format for the animations is set to PPM.
> To build the above... compile the ogsf library, execute configure from
> NVIZ2.2, execute make from NVIZ2.2 to build the new NVIZ executable and
> install the scripts in the appropriate place.
> Let me know if there are any problems.
> Bob Covill
> Tekmap Consulting
> P.O. Box 2016
> Fall River, N.S.
> B2T 1K6
> Canada
> E-Mail: bcovill at tekmap.ns.ca
> Phone: 902-860-1496
> Fax: 902-860-1498
If you want to unsubscribe from GRASS Development Team mailing list write to:
minordomo at geog.uni-hannover.de with
subject 'unsubscribe grass5'
