[GRASS5] bugs-rst-rflow
Helena Mitasova - staff helena at gis.uiuc.edu
Fri Sep 29 10:11:10 EDT 2000
Rado (resamp.rst question) could you email me
the full comand you are running ? (is z_50 input or output?)
David (r.flow question) the -M flag has never been tested
so there indeed may be a bug - are you getting that even if
you run it with a small file? The problem may be also with the
segment library which is used e.g. in r.watershed for large
data sets. Is the -M option really needed? Is the aspect(dir) that
you are using derived from your DEM (fill) or is it different?
please answer directly to helena at gis.uiuc.edu
Helena
If you want to unsubscribe from GRASS Development Team mailing list write to:
minordomo at geog.uni-hannover.de with
subject 'unsubscribe grass5'
