[GRASS5] CRAY T3E compile errors
Markus Neteler neteler at geog.uni-hannover.de
Mon Sep 25 12:29:57 EDT 2000
Hi Justin,
many thanks again...
On Mon, Sep 25, 2000 at 12:17:43PM +0700, Justin Hickey wrote:
> Hi Markus
> Most of these can be fixed by casting, and it appears that most of the
> casts will be OK. I have noted which ones need some care.
> Markus Neteler wrote:
>>v.cutter:
> >   Argument of type "struct poly_vert_info **" is incompatible with parameter
> > of
> >           type "void **".
> >                 swap_pointers (&Vert, &Vert2);
> This one should be safe to cast.
> > of
> >           type "void **".
Both are casted now. It compiles o.k. on CRAY now.
> >   Argument of type "pntDescript ***" is incompatible with parameter of type
> >           "void **".
> >     res = btree_find( hDB, keyHolder, &dataHolder );
> Already fixed by David (I think)
That's right.
>v.out.mapinfo:
> >   Argument of type "struct Map_info **" is incompatible with parameter of
> > type
> >           "struct Map_info *".
> >             Vect_close (&Map);
> Looks like a typo, perhaps Map is declared as a pointer already and
> passing the address of Map is passing a double pointer, thus the
> conflict. You can verify this if other calls to Vect_close exist.
> Otherwise, I still think it is safe to simply remove the "&" from Map.
> Note this also applies to the second error. Another thing you could do
> is check the code in Vect_close to see how Map is used. If it is used as
> a single pointer then you can get rid of the "&".
Bingo. It was a typo, I have fixed it.
> >   The struct "<unnamed>" has no field "_shortbuf".
> >       while (match == 0 && Closet->dig_fp->_shortbuf[1])  /* try to upgrade
> > in 5/2000 */
> Ahh! This one happened to me as well. There are #ifdef's in place
> already for this line in the code. In the code they check for a struct
> member called _cnt for SGI, and _bf._size for CYGWIN and FreeBSD. Check
> the file /usr/include/stdio.h to see if either of these members are
> inside the FILE structure. If it is there, then add the appropriate
> "defined (cray)" check (just guessing on the cray part, you will need to
> verify the proper variable name) in the source code. If there is no
> match in the FILE struct, then send the FILE struct details to me and I
> will see if I can determine the proper member to check. It may be the
> same as the SGI line since SGI owned (or still does own) Cray.
Yep. I have added CRAY to _cnt (like SGI). Now this one compiles, too.
> > "binfer.l":line 13: Error: Missing translation value
> > Make: "lex binfer.l": Error code 1
> > -> looks like a problem with  "%option lex-compat"
> No idea with this one.
Hello lex-professionals! Any ideas? This is the last bug to be fixed
on CRAY. All other basic modules compile.
Thanks to all who have helped here!
Markus
If you want to unsubscribe from GRASS Development Team mailing list write to:
minordomo at geog.uni-hannover.de with
subject 'unsubscribe grass5'
