[GRASS5] total cells overflow
GRASS grass at geni.knu.ac.kr
Thu Sep 7 06:45:10 EDT 2000
From: Markus Neteler <neteler at geog.uni-hannover.de>
> while defining a new location (a large one) I got:
>   total rows:            58400
>   total cols:            65600
>   total cells:   -,463,927,296
> total cells should be 3831040000
> How can I fix this? Brain overload?
> Yours
>  Markus
Well, if you have only printout problem, there is a way to fix that.
By the way, I don't know why `unsigned int' doesn't work at all.
`unsigned int' and 'signed int' work same way, the same range.
`unsigned int' accepts negative integer value too :-(.
Best Regards,
Huidae Cho
If you want to unsubscribe from GRASS Development Team mailing list write to:
minordomo at geog.uni-hannover.de with
subject 'unsubscribe grass5'
