[GRASS5] total cells overflow
Justin Hickey jhickey at hpcc.nectec.or.th
Thu Sep 7 05:48:33 EDT 2000
Hi Markus
Markus Neteler wrote:
> while defining a new location (a large one) I got:
>   total rows:            58400
>   total cols:            65600
>   total cells:   -,463,927,296
> total cells should be 3831040000
It appears that the total cells value is stored as a signed 32 bit
integer. The largest value that can be stored in such a variable is 2.14
* 10^9 (2.14 billion). Your value is greater than that so the only
solution I can think of is either change the variable storing the total
cells to an unsigned 32 bit number, which should be fine since negative
cells are invalid. Or create a smaller map.
Hope this helps.
Sincerely,
Jazzman (a.k.a. Justin Hickey)  e-mail: jhickey at hpcc.nectec.or.th
High Performance Computing Center
National Electronics and Computer Technology Center (NECTEC)
Bangkok, Thailand
People who think they know everything are very irritating to those
of us who do.  ---Anonymous
Jazz and Trek Rule!!!
If you want to unsubscribe from GRASS Development Team mailing list write to:
minordomo at geog.uni-hannover.de with
subject 'unsubscribe grass5'
